FCP matching progressive footage with an interlaced sequence?
Hi everyone,
I have been working on a project with HD footage (1920×1080, 25 fps, compressed in Apple ProRes 422 HQ). I am 100% positive the footage is progressive, but when i drag it into my timeline and have FCP match the sequence settings with the footage settings, FCP sets the sequence to aspect ratio: HDTV 1080i (16:9). The other settings match the clip settings regularly (1920×1080 frame size, 25fps, apple pro res etc). Do you have any idea why FCP sets my sequence to interlaced? If I don’t change my sequence settings, the progressive footage will eventually be exported as interlaced, am I right?
Would I just need to change my aspect ratio into custom 16:9? How can I be sure that my sequence is set to progressive?Thank you
