Activity › Forums › Apple Final Cut Pro Legacy › FCP Markers to podcast
  • FCP Markers to podcast
    Posted by John Schreck on July 5, 2009 at 9:51 pm
    I placed markers in FCP audio file and output to M4v (output quicktime converter to ipod). How do I get the markers to show up in an enhanced podcast? Do I need other software? Do I output it different?
    Paul Figgiani replied 17 years, 2 months ago 3 Members · 2 Replies
  • John Pale
    July 6, 2009 at 5:00 am
    You can convert FCP markers to podcast markers in Soundtrack Pro.
    Can’t give you a step by step, as I am not in front of a system, but I have done it and it works. Check Soundtrack Pro Help, I think it’s in there. It’s not just for audio podcasts… It work with video podcasts too.
  • Paul Figgiani
    July 6, 2009 at 2:26 pm
    John is correct.
    Display the Podcast Track in STP (upper right popup menu located in the multi-track workspace). When you select this track the Podcast Marker input data fields appear in the Details tab. Easiest way to add a marker to the selected track is … ⇧ ⌘ M …, that’s shift+command+M.
    Remember there is a difference between an Enhanced Podcast, which is an audio file (AAC, MPEG-4 wrapper, .m4a file extension) and a QT movie with chapter markers. The audio .m4a supports reference stills and hyperlinks. If you are exporting a video file, the “Podcast Markers” appear a standard Chapter Markers.
    Make sure you export properly – File Type: AAC/Podcast File. You can set the format to include the audio only “enhanced images” or a video track.
    -paul
