Activity Forums Apple Final Cut Pro Legacy FCP losing audio sync after renders
  • FCP losing audio sync after renders
    Posted by Herb Sevush on February 12, 2007 at 9:47 pm
    This is beginning to drive me crazy. Here’s the situation.
    Dual 2.5 G5 with 3.5gig of memory. FCP 5.1.2 – the binary cross-grade.
    Ever since installing the binary cross-grade the audio in FCP drifts our of sync on playback after a render, especially if i have been bouncing back and forth to Motion. The solution is to close out of FCP and then re-open, but this is a major pain in the a**. I’m using fibre channel arrays and only editing DVCPRO 50, so I doubt it’s drive speed. I’ve re-installed the complete FCP studio and all drivers numerous times, everything up to re-installing the MAC OS. I don’t have this same problem on my Quad Intel Mac. It feels like it’s a memory issue – but then what do I know. does anyone have any ideas.
    Herb Sevush
    Zebra Productions
    Ron James replied 19 years, 7 months ago 2 Members · 3 Replies
  • Ron James
    February 12, 2007 at 10:52 pm
    Make sure your renders aren’t going to your system drive.
  • Herb Sevush
    February 13, 2007 at 3:57 pm
    The renders are going to the main fibre channel Xraid. Any other thoughts?
    Herb Sevush
    Zebra Productions
  • Ron James
    February 14, 2007 at 10:47 pm
    The only other thing I can think of is to check your render/rt quality and force full renders everytime (so there’s no real-time happening). Or, when doing a render, go into the render menu and select a full render (I find option-r doesn’t do it, as I would expect it to) and do an audio mixdown.
    Hope this helps…
