Activity › Forums › Apple Final Cut Pro Legacy › FCP Loses Renders
FCP Loses Renders
Posted by Andy Lancaster on September 7, 2008 at 2:31 pmI am having a problem with FCP (6.0.4) sequences becoming unrendered. I will render the entire sequence and then the next time I open that sequence it needs to be rendered again. Is there a reason for this and maybe a solution?
Rafael Amador replied 17 years, 11 months ago 4 Members · 8 Replies -
Rafael Amador
September 7, 2008 at 2:53 pmhi Andy,
That issue was very common back in FC 5.1.x (think was that) but was fixed.
I really haven’t heard of this problem in FC 6.
Rafael -
Don Greening
September 7, 2008 at 7:06 pm[Jeremy Garchow] “Got Smoothcam on your clips by chance?”
I do and they lose their affiliation with the render files every time I re-open the project. Is there a work around, all seeing, all knowing, Mr. Garchow?
– Don
FCP 6.0.2
QT 7.3.1
OS 10.4.11
4 core Mac Pro -
Jeremy Garchow
September 7, 2008 at 7:10 pm[Don Greening] “Is there a work around, all seeing, all knowing, Mr. Garchow? “
No. No, there’s not and it’s highly annoying, unless you call exporting all of your clips and reimporting them as ‘hard’ media a work around.
Join the cause:
https://www.apple.com/feedback/finalcutpro.html
Don Greening
September 7, 2008 at 7:19 pmThanks, Jeremy. The cause is officially joined. Thanks for the link.
– Don
Jeremy Garchow
September 7, 2008 at 11:39 pmYou’re very welcome. Hope it’s fixed soon as SmoothCam is the bee’s knees.
Don Greening
September 9, 2008 at 5:01 am[Jeremy Garchow] “Hope it’s fixed soon as SmoothCam is the bee’s knees.”
I heard that. Funny thing about the smooth cam renders. If I do smooth cam on the native XDCAM 1080p 30 clips the renders are never there the next time I open the project. But awhile back I down converted some stuff to DV NTSC first and then applied smooth cam to a few clips that needed it and those renders are rock solid. weird.
– Don
Rafael Amador
September 9, 2008 at 6:18 amHi Don,
As long as FC don’t delete the render files, you can always bring them manually to your Browser.
rafael
