Activity Forums Apple Final Cut Pro Legacy FCP Log and Transfer Dropped frames
  • FCP Log and Transfer Dropped frames
    Posted by Alfred Wells on September 27, 2011 at 3:35 am
    Hi All,
    Been having some trouble with Log and Transfer in FCP 7.0.3.
    Doesn’t matter what type of file I’m trying to transcode to ProRes, whether it be H.264 from a 5D/7D/Rebel or a Sony XDCAM format to that appleXD codec.
    Either way, at some point during the transcode of a longer file, a red exclamation point will appear and the file will be incomplete. I believe this has something to do with dropped frames?
    Anybody know of way to fix this? Any help would be greatly appreciated.
    Thanks.
    Alfred Wells replied 14 years, 11 months ago 4 Members · 4 Replies
  • Steve Eisen
    September 27, 2011 at 1:35 pm
    You do not drop frames when you transcode. Drop frames are caused by slow hard drives during playback.
    FCP likes it when you have the complete card structure when log and transferring tapeless media.
    What is your exact workflow?
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Jules Bodenstein
    September 28, 2011 at 1:25 pm
    It sounds like it may be an issue with the amount of ram you have – what is spec for your system?
    Gaz Evans
    Workflow Technician
    The diROOM
    https://www.diROOM.com
  • Gary Lieberman
    September 29, 2011 at 1:13 pm
    I have the same problem with 5d Mk II H264 footage.
    I’ve had the red exclamation point on a file – truncated well before the end. Re-transferring it worked out fine (even though the file ingested was given a new filename).
    Unfortunately, I’ve had several files ingesting (seemingly) fine, only to realize they are truncated, sometimes minutes from the end, with no logging errors during ingestion.
    I am not setting In/Out points during L&T
    I’ll try Log and Transfer one file at a time perhaps to see if it’s some RAM issue… My file lenghts go from 10 secs to 10 mins, but this happens on 1 minute files as well….. any other thoughts?
    I’ve started editing, so now it’s a nightmare to go back and check H264 v. ProRes LT file-lengths one by one!
    2 x 2.66 Dual-Core Xeon
    13 Gb RAM
    OS X 10.6.8
    FCP 7.0.3
  • Alfred Wells
    September 29, 2011 at 10:05 pm
    Yeah,
    This is exactly what happens to me when working with log and transfer in FCP. The files don’t completely finish transcoding. Then I need to double check the lengths of the prores with the original H264.
    I remember it working a bit better when doing one at a time. Totally possible that it’s the RAM seeing as it works sometimes and not all the time
    Need to troubleshoot further and figure out what’s up
