Activity Forums Apple Final Cut Pro Legacy FCP locking up during layoff
  • FCP locking up during layoff
    Posted by Gene Bauer on July 31, 2007 at 5:36 pm
    Getting an error while laying off in Final Cut Studio 5.1. The footage was captured via a Declink Extreme card uncompressed. The error states RT Extreme dropped frames could be caused by
    -slow disks
    -too many RT layers
    -RT Bandwith settings in user prefs
    Any ideas besides the above?
    Adam Taylor replied 19 years, 1 month ago 5 Members · 5 Replies
  • Shane Ross
    July 31, 2007 at 5:42 pm
    Well, what drives are you using to store the media? Is everything FULLY rendered? No DARK green bar, but light blue. How many layers of video do you have?
    before I output, I always export my sequence as a self contained QT file, so that FCP references only ONE file when outputting.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Gene Bauer
    July 31, 2007 at 8:04 pm
    Everything is fully rendered, one layer of video and I’m using a GRAID2 as my primary scratch disk. I also should have mentioned it will lock up with same warning just playing on the timeline. We tried trashing the preferences with no luck and ran repair permissions on all hard disks. It is more than just one project.
  • Digi07
    July 31, 2007 at 8:54 pm
    Are you rendering to the same drive as where your media is stored? If not, that may be causing the problem; the gap between the render files and the media.
  • Jeremy Garchow
    July 31, 2007 at 9:47 pm
    What codec are you laying off?
  • Adam Taylor
    August 1, 2007 at 7:55 am
    I am having exactly the same problem, and it has only started since i upgraded to FCS2.
    My system comprises G5 Quad, 4gb ram, Xserve raid (both fibre channels connected to my G5), Kona 3, 10 bit uncompressed Pal.
    As i’m working on commercials, its not as if i have hours of footage on a timeline either.
    Render files are all stored on same Xserve raid as all the other footage, and i’m the only user connected to the raid
    Prior to FCS2 – it was a very stable system…now i am having quite a few very flaky problems with lots of different areas of the software! Cetainly not Apples most helpful upgrade.
    Adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
