FCP Live capture DV on G4?
Hello all, I have a shoot coming up and would like to do some live capturing on the set to rough cut shots for continuity purposes. We would be using a Powerbook G4 1 gig processor/1 gig ram, external FW raid. Our plan is to take the charactor out of the beta record deck, use a Canopus converter to get it to a DV signal and capture through the FW400 port. We would have a raid/external drive on the FW800 port. Has anyone done this? Does it work? Are there any pitfalls that we should be aware of? Has anyone else tried to use a keyspan to get timecode off of a deck at the same time? Any help in these matters would be appreciated.
Doug Ohlsen
CUT
612-423-3348
