Activity › Forums › Apple Final Cut Pro Legacy › FCP keeps quitting
  • FCP keeps quitting
    Posted by Tony Pierce on January 4, 2006 at 5:52 am
    Suddenly my FCP 4.5 quits after any brief attempt to use it. Have been through this before — and trashing prefs solved it — but not this time. Any other ideas? I am hurting on time. Thanks.
    Don Greening replied 20 years, 8 months ago 3 Members · 5 Replies
  • Don Greening
    January 4, 2006 at 7:26 am
    Quicktime is also active when FCP is running, so you might try trashing the QT prefs as well. There are two QT pref files but I don’t know which one will contain your QT Pro serial number, so be prepared to input the number once QT is up and running again afterwards. Drag both files onto the desktop but don’t trash then right away. Start Quicktime and make sure it’s running properly as a stand alone app. If that checks out then start FCP and see if trashing the QT files made a difference. If that solves it then you can safely drag the old QT pref files off your desktop and into the trash.
    Macintosh HD/users/your name/library/preferences/com.apple.quicktime.plugin.preferences.plist (and also) com.apple.quicktimeplayer.plist
    – Don
  • Tony Pierce
    January 4, 2006 at 8:08 pm
    Thanks — but it did not work. I am entering crisis mode — any other ideas??
  • Matthew Brunn
    January 4, 2006 at 8:20 pm
    Try loading the FCP without the project. If it loads, try to load your edit without media. Narrow down what is corrupt. See if you can load without the filters. I had a filter go bad once. Just reinstalled the filter and bingo!
  • Tony Pierce
    January 4, 2006 at 8:27 pm
    Thanks — it seems to be just in this project, not others. How would I load it without the media? And if the media is corrupt, what would I do about it? Or how would I load without filters? thanks, I appreciate your help.
  • Don Greening
    January 4, 2006 at 8:47 pm
    You could also go to your autosave vault and try to work with an earlier version of your project. The most recent version of your project file may have become corrupted, but earlier versions may not be. Another thing to check is there may be a corrupt render file. Try going to your project’s render folder and rename it so FCP doesn’t recognize it as the render folder. Create a new empty render folder so FCP recognizes that one. Start your project and if it works, FCP will tell you it can’t find the old render files, so just choose to bypass the old renders and re-render everything again.
    – Don
