Activity Forums Apple Final Cut Pro Legacy FCP Is the Field Order Selectable from Source or Fixed?
  • FCP Is the Field Order Selectable from Source or Fixed?
    Posted by Mpigott on August 8, 2005 at 3:03 pm
    I am about to use FCP (on a Dual Mac G5) and import image sequences generated
    in 3ds Max….
    Now I am going to need to field render in NTSC and I have this small question about
    FCP (I have never even touched this progam or the Mac yet)
    a)if I render in fields (lower) in 3ds Max, do I have a choice of whether I can pick
    the field dominance from a menu in FCP, or
    b) The field order is fixed in FCP, and I need to select the field order CORRECTLY in 3ds Max?
    I hope a) is the case!
    FCP Super Noobie
    Jerry Hofmann replied 21 years, 1 month ago 2 Members · 1 Reply
  • Jerry Hofmann
    August 8, 2005 at 5:54 pm
    (a) is correct…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
