Activity Forums Apple Final Cut Pro Legacy fcp interlacing problem
  • fcp interlacing problem
    Posted by Oliver Lynch on March 6, 2007 at 11:36 pm
    I have been having the same issue with interlacing. I am trying to export footage as avi or dv using Quicktime conversion, the footage does not show interlacing while working in fcp but shows drastic interlacing after being exported as anything I have tried so far and with progressive scan set lower upper fields?. thanks
    Oliver Lynch replied 19 years, 6 months ago 2 Members · 6 Replies
  • Jeremy Garchow
    March 7, 2007 at 1:26 am
    [standfast] “I have been having the same issue with interlacing”
    Same issue as what? Video is interlaced unless you are shooting 25p or 30p. If you shot 24p, then every 4th and 5th frame is interlaced. What’s the problem?
  • Oliver Lynch
    March 7, 2007 at 8:41 pm
    When I export using quick time conversion the interlacing becomes very noticeable compared to the un exported version. Thanks for the help
  • Jeremy Garchow
    March 7, 2007 at 8:50 pm
    Why are using Quicktime Conversion?
  • Oliver Lynch
    March 8, 2007 at 12:19 am
    I am trying to create an avi or dv file from final cut. the only options i found to export in those formats that I have are quicktime conversion and compressor and they both gave the same result
  • Jeremy Garchow
    March 8, 2007 at 3:03 am
    If you are working in a DV timeline, all you have to do is go to export quicktime movie (not Quicktime conversion) and choose current settings. If you need to move the resulting export to another machine, check the ‘make self contained’ box. Leave the recompress all frames UNchecked. This will make a Quicktime movie in the DV codec. Don’t use quicktime conversion.
    Jeremy
  • Oliver Lynch
    March 9, 2007 at 1:14 am
    thanks
