Activity › Forums › Apple Final Cut Pro Legacy › FCP importing
FCP importing
Posted by Omnidecay on July 18, 2007 at 6:09 amOK, so I google searched the sony HDR-FX1 and I cant seem to link up with my comp for the life of me. No additional icons appear once plugged in, no sound is made and when I hit log and capture. A pop up says “unable to initialize capture device”. This is the first time I have used a camera to capture footage so sorry if this is a repeated easy fix.
Thank you
Omnidecay replied 19 years, 2 months ago 3 Members · 10 Replies -
13
July 18, 2007 at 7:10 amAre you capturing HDV or DV?
If you are capturing DV was it shot in HDV?
What are your settings in FCP.Your settings in FCP determine what type of video signal FCP looks for. If the camera is not set to send that signal out the firewire connection then, its like the computer is speaking english and the camera is speaking german.
If you are trying to capture HDV and have FCP set for HDV yet have your camera set to send out a DV signal then they are speaking different languages.
Remember the FX1 can play back video shot in HDV as DV footage. So if you are trying to capture HDV but the camera is set to send out a DV signal, they will not communicate.
Omnidecay
July 18, 2007 at 8:30 amSorry for my ignorace but this is also the first time I have even touched this camera (its not mine). How do you switch the camera from DV to HDV :-)?
Thank you
Omnidecay
July 18, 2007 at 8:48 amIm sorry, I figured out how to change it from DV to HDV. This did not fix the problem, FCP/computer will still not recognize the camera. Im at a bit of a stand still.
Omnidecay
July 18, 2007 at 11:31 pmSequence Preset- HDV – 1080i60
Capture Preset: HDV
Device Control Preset: Sony HDV FireWire
Playback Output Video: None
Playback Output Audio: Default
Edit to Tape/PTV Output Video: HDV (1440 x 1080) 60i
Edit to Tape/PTV Output Audio: Defult -
13
July 18, 2007 at 11:38 pmThose settings look right, double check the camera, play back settings.
If that douse not do it then, see if you can capture in DV this will let you know if the firewire connection on the camera and your cable are working.
Omnidecay
July 18, 2007 at 11:46 pmThe footage was captured on DV mode. When I switch the camera from DV to HDV a window in the camera viwer pops up saying “No output image in VCR HDV/DV, change format.
13
July 18, 2007 at 11:52 pmIt sounds like ether the camera isnt set right or you are playing a tape that was shot in DV not HDV
Hill60
July 18, 2007 at 11:59 pmSo, if your video was captured as DV, then you’ll want your FCP settings to reflect that.
Try setting your Capture to DV, rather than HDV.
Set your device to Sony DV Firewire.
