Activity › Forums › Apple Final Cut Pro Legacy › FCP import footage from a NXCAM
Shane Ross
December 7, 2010 at 5:57 am[shane godfrey] “Any further I ideas?”
As stated two times before…ClipWrap2.
Shane
Read my blog, Little Frog in High Def -
Dennis Radeke
December 7, 2010 at 10:41 am[shane godfrey] ” I do have CS5 premiere, have you or anyone else heard if it works with it?”
The camera is an AVCHD camera: https://pro.sony.com/bbsc/ssr/micro-nxcamsite/cat-broadcastcameras/product-HXRNX5U/?PID=I:nxcamflashbanner_hxrnx5u:hxrnx5udetails
Therefore, you can edit natively in Premiere Pro CS5.
Shane Godfrey
December 7, 2010 at 1:56 pmThanks again for the help.
What I do not understand is the fact that I have the entire file structure in tact with the card, and I can’t choose the files when I “log and transfer”. I see all of it on the menu, but it is grey and I can’t select. Is this a known problem with FCP and this camera, you said you were able to import, but it was slow. I will get ClipWrap2 if that is my only solution, but I wonder if there is another problem? Would it make a difference if I connected the camera with the card in the camera? I would not think so…
I would rather not have to spend $50 for Clipwrap if I can help it… -
Shane Ross
December 7, 2010 at 2:35 pm[shane godfrey] ” Is this a known problem with FCP and this camera, you said you were able to import, but it was slow.”
I’ll wager that it is because you are using FCP 6. That camera is relatively new, and uses a NEW version of AVCHD (there is no AVCHD standard, unfortunately), and FCP 6 might not understand the file structure. But FCP 7 includes updates that recognizes that card structure.
[shane godfrey] ” Would it make a difference if I connected the camera with the card in the camera? I would not think so…”
I doubt it.
Shane
Shane Godfrey
December 7, 2010 at 2:38 pmOK thanks, I will investigate what it will cost to step up to FCP 7
Gergo Szabo
December 7, 2010 at 8:31 pmWe had the same problem. While we didn’t find the update for the FCP we recompressed It to DV-PAL .mov with MPEG Streamclip (watch for the pixel aspect ration if you shot in 16:9). And the interlaced look is disappeared.
Shane Godfrey
December 8, 2010 at 2:07 amthanks alot, I just made the video in Premiere and it looks great… never worked with AP much, but I had it so… I like it
