FCP Help
Howdy neighbors, what a great resource for a novice like me. I have small problem I could use some help with, I’m in the process of learning FCP7 shortcuts and somehow I activated a filter of some kind, best described as a green circle with a check mark, as well as diagonal green stripe in the bright highlights of the sample footage I’m using in the viewer window. Anyone have a suggestion as to getting out of this?
Thanks in advance for any consideration!
