Activity › Forums › Apple Final Cut Pro Legacy › FCP HDV Transition will not apply to timeline
  • FCP HDV Transition will not apply to timeline
    Posted by Greg Manahan on March 14, 2009 at 4:27 pm
    I have a Sony HDR-FX7 and just started pulling in clips from a single tape. I have about 10 different clips off the tape applied to the timeline. I’m trying to drop some transitions on the clips and it will not allow me to add them to most. 2-3 do allow me to add them. But only to the left side of the transition not both.
    Any ideas on what may be wrong?
    David Roth weiss replied 17 years, 6 months ago 2 Members · 1 Reply
  • David Roth weiss
    March 14, 2009 at 5:49 pm
    Go to the FAQ at the top of the FCP Forum https://forums.creativecow.net/faq/applefinalcutpro#47 and see the answer to question D-1.
    To save you some time, here’s that answer…
    Can’t add a Transition / Transition is only 1 frame / I get “Insufficient Content”
    Shane’s Stock Answer #1
    You need to make sure that your clips have enough media (called ‘handles’) at the beginning of the incoming clip and at the end of the outgoing clip for the transition. For example, if you have a 1 second (30 frame) dissolve, your in and out point need to be at least 15 frames from the edge of the clip.
    What you are running into is that you are marking an out point at the end of a clip then adding a cross dissolve, say 20 frames in duration. Since the dissolve is centered on the cut, it will start 10 frames before the cut, and try to go 10 frames AFTER the cut…which it can’t do.
    What you need to do is plan how long your dissolve will be and back-time your cut so that it works.
    A full 1 second crossfade reaches 15 frames into each clip. So, if you want to change a cut to a crossfade, there has to be at least 15 additional frames of each clip.
    Say you’re trying to crossfade from one clip into the very first frame of a second clip. FCP cannot ‘create’ 15 more frames of the second clip to do a crossfade. If they’re not there, you’re out of luck.
    FCP has to extend the end of your first clip by 1/2 of your transition length, and the beginning of your second clip by 1/2 of your transition length, so those frames need to be in your system. The nature of a crossfade is mixing two clips together.
    For more of Shane’s Stock Answers visit:
    https://library.creativecow.net/articles/ross_shane/fcp_faq.php
    https://library.creativecow.net/articles/ross_shane/fcp_faq2.php
    https://library.creativecow.net/articles/ross_shane/fcp_faq3.php
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
