Activity Forums Apple Final Cut Pro Legacy fcp hdv export
  • Posted by Tommy V. wier on May 18, 2006 at 4:12 am
    ok, problems exporting fcp hdv project to dvdsp. Can’t do it the old way of straight mpeg-2 out(which took about 45 min). Have tried various settings (quicktime; quicktime conversion; current settings; reference..etc) that took from 6 to 35 hours in Compressor- and still didn’t work. What are the best procedures & settings for highest quality export for a 30 min hdv project that dvdsp will accept?
    Tommy V. wier replied 20 years, 4 months ago 2 Members · 2 Replies
  • Ramendemon
    May 18, 2006 at 1:32 pm
    If you want your final output to be letterboxed, I’ve found that you can copy your sequence and paste it into a standard def timeline. Then let it render out, export QT movie, then drag it into compressor. The rendering time should be a little bit longer than the length of the sequence, but for me it has the best results. Doing it this way is also faster because Compressor encodes SD a lot faster than HDV. In fact, I’ve found that HDV renders generally take longer than DVCProHD. Hope this helps. Good luck.
  • Tommy V. wier
    May 21, 2006 at 11:18 pm
    Your suggestion did work for footage, but for some reason graphics did not scale into letterbox. They are expanded out beyond safe action. Any suggestions?
