FCP HD Video importing to AE @ 1 fps Help
I am having problems today with pretty much every video that I export from FCP and then import into AE. AE is reading it as 1 fps and when I go to interpret footage it is just shortening the clip when I select 23.976. Below are my settings:
FCP Sequence:
1920X1080 HDTV 1080 (16:9)
Pixel ratio: Square
Editing Timebase 23.98
Compressor: Uncompressed 10-bit 4:2:2FCP Export Settings: (file->export->quicktime conversion)
Compression: Animation (done this for all projects)
FPS: Current
Millions of Colors+
High QualityI can watch it normally in QT, however once I import it into AE it goes straight to 1 fps.
I have tried everything I know, please help! Deadline with clients!
