Activity › Forums › Apple Final Cut Pro Legacy › FCP HD to 5.0
  • Posted by Seawild on April 18, 2006 at 7:42 pm
    Hello All,
    I am currently using 4.5 on my Powerbook. I have client who needs to borrow it and install FCP 5 on it. Should I delete 4.5 app? What else should I do before he installs FCP5?
    Thanks Chris
    Seawild replied 20 years, 5 months ago 2 Members · 2 Replies
  • Shane Ross
    April 18, 2006 at 9:22 pm
    THEIR copy of FCP 5…on your machine? When they are done with it you will have to remove it and reinstall FCP 4.5.
    You can install FCP 5 on top of 4.5…it will just change the version. Then, when you are done with FCP 5, remove it and reinstall FCP 4.5:
    How to uninstall FCP 5
    Here’s the way to do it:
    1) Close FCP
    2) Go to: /users/username/library/preferences/
    a. Delete the com.apple.FinalCutPro.plist
    b. Delete the FCP User data folder.
    3) Go to: Applications
    a. Delete FCP application
    b. Delete FCP HD addition easy setups folder.
    4) Go to: /library/applicaton support/fcp system support/
    a. Delete Custom Settings folder
    b. Delete Plugins folder
    5) Go to: /library/receipts/ and delete the following:
    a. AnalogPAL.pkg
    b. AppleIntermediateCodec.pkg
    c. DigitalPAL.pkg
    d. DVCproHDCodec.pkg
    e. FinalCutPro.pkg
    f. FinalCutproHDUpdate4.5.pkg
    g. FinalCutProHelp.pkg
    h. HDVCodec.pkg
    i. IMXCodec.pkg
    j. Uncompressed422.pkg
    k. VideoOutSupport.pkg
    6) Insert the FCP 5.0 upgrade disk and re-install.
    7) Run the OSX Disk Utility
    a. Select the OSX drive
    b. Repair the Disk Permissions.
    c. Reboot.
    8)Run Software update to get back to 5.0.4.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Seawild
    April 18, 2006 at 10:55 pm
    Thanks Shane!
