Activity Forums Apple Final Cut Pro Legacy FCP HD Online procedures
  • FCP HD Online procedures
    Posted by Paula Stein on December 19, 2006 at 2:36 am
    I am needing to online a feature length documentary shot on Panasonic DVCpro50 HD tapes.
    The system is set up for HD with a ASHA capture card. FCP 5.1.4 software.
    The off-line was digitized standard def, 24p.
    I need to get the step by step procedure for doing the online myself. Thanks for your help.
    Walter Biscardi replied 19 years, 8 months ago 3 Members · 5 Replies
  • Shane Ross
    December 19, 2006 at 4:44 am
    [Paulahope] ” system is set up for HD with a ASHA capture card.”
    Do you mean AJA? Which card? Knowing which one will help us determine what your system is capable of doing.
    [Paulahope] “Panasonic DVCpro50 HD tapes”
    DVCPRO 50 is Standard Def, not high def. DVCPRO 100 is HD…called DVCPRO HD.
    [Paulahope] “The off-line was digitized standard def, 24p”
    Yes…as it should be. DVCPRO 50 is a standard def format.
    What do you need to output to?
    Shane
    FCP Preferences set to UNCONTROLLED ADVICE
    Littlefrog Post
    http://www.lfhd.net
  • Shane Ross
    December 19, 2006 at 5:01 am
    [Paulahope] “FCP 5.1.4 software. “
    Oh, and this is a FUTURE version of FCP…because the most current version is 5.1.2…
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Paula Stein
    December 19, 2006 at 6:26 am
    Shane:
    I believe the card is a AJA cature card.
    Thanks for setting me straight on the DVCPro50 – SD format and DVCPRO 100 being HD
    I believe it will be output to a tape and DVD What do you recommend?
    Please continue..I am all ears about the rest of the steps.
    Paula
  • Shane Ross
    December 19, 2006 at 9:12 am
    [Paulahope] “I believe the card is a AJA cature card. “
    Which AJA card? There are many.
    [Paulahope] “I believe it will be output to a tape and DVD What do you recommend?”
    What does your client want? What is your intended distribution market? Does it need to be HD?
    [Paulahope] “Please continue..I am all ears about the rest of the steps.”
    This is where you need to hire an experienced editor who knows what to do. This is a help site to assist when you have an issue to be resolved. If you need to know how to do something from start to finish, you need to hire someone to consult or to do the work.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Walter Biscardi
    December 19, 2006 at 11:53 am
    [Shane Ross] “[Paulahope] “Please continue..I am all ears about the rest of the steps.”
    This is where you need to hire an experienced editor who knows what to do. This is a help site to assist when you have an issue to be resolved. If you need to know how to do something from start to finish, you need to hire someone to consult or to do the work.”
    Or simply practice trial and error like we did with Good Eats. I spent about 6 months developing our HD workflow with the D.P. 2 years ago when there was very little useful information about HD Post out there. It took a while, but now we have a very simple HD Post workflow.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
