Activity › Forums › Apple Final Cut Pro Legacy › fcp HD device control problem
  • fcp HD device control problem
    Posted by Josh Snider on July 15, 2005 at 11:55 am
    hi, i just installed OSX.3.9 on my iMac G4, in order to install fcp HD. i had previously been working with fcp 3. the first thing i tried was to capture some footage from my CAM (PD-150). in capture presets it says “firewire missing”, but it gives me this other option of “Desktop Cinema Preview-Main” which has a screen size of somthing like 1090×1820.
    when i log and capture using either “none” or the “Desktop Cinema…” preset, i can control my camera through my computer, and i can see the running timecode of the tape on the log and capture window, but the image won’t come up in the window, and it won’t capture the footage. (iMovie works fine).
    there’s a warning in the capture preset window that says to check the Final Cut HD website to see if i should use “firewire” or “firewire basic” for my specific camera. but i can’t find any such website. i tried firewire basic as the device control preset as well, but it didn’t make a difference.
    when the preset is set to “Desktop Cinema Preview-Main” the entire screen is often times black, and it becomes more of a hassle.
    does anyone know what’s going on here?
    would it help to strike my hard drive and reinstall everything?
    (through the installation process, my version of fcp 3 seems to have been updated and has the same problem)
    josh
    Josh Snider replied 21 years, 2 months ago 2 Members · 2 Replies
  • Walter Biscardi
    July 15, 2005 at 2:57 pm
    OS 10.3.9 is not required to run FCP 4.5 (also known as FCP HD). If that’s the version you’re running, you’re better off running OS 10.3.8.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Josh Snider
    July 15, 2005 at 4:11 pm
    i installed OSX.3.0, but i needed 10.3.2 to run fcpHD, so i connected to the internet and the software updates automatically updated me to 10.3.9.
    what’s the difference bewteen 10.3.8 and 10.3.9?
    josh
