Activity › Forums › Apple Final Cut Pro Legacy › FCP HD. Can’t switch External Video to “All Frames” on
Posted by Christopher Bagnall on November 23, 2005 at 2:19 amAs I said above, I can’t switch External Video to “All Frames” on for some reason. I haven’t changed anything but it is not working. It is a Non Controllable Device. Any advice would be appreciated thanks.
Joseph Bradley replied 20 years, 10 months ago 4 Members · 6 Replies -
Debe
November 23, 2005 at 2:26 amQuit FCP and restart with the non-controllable device on first.
If you turned on the device after you had launched FCP, it just didn’t know that now there is a device there, so it doesn’t know that “All Frames” is now an option.
debe
Christopher Bagnall
November 23, 2005 at 3:17 amI did that with no luck. it is odd. It won’t let me even select the option for “All Frames” or “Single Frames” in the External Video window. I unplugged all devices and replugged. I am using my DV camera as a bridge and can see the image in the camcorders viewfinder. As I said nothing has ever changed. Any ideas? Thanks
Debe
November 23, 2005 at 3:44 amHow about the ol’ power down and power up everything but the CPU first…
What is your A/V Devices in your A/V Settings set to? Perhaps that got set to something funky?
That’s in the menu Final Cut Pro HD>Audio/Video Settings, or Option+Command+Q.
debe
Rob Forsythe
November 23, 2005 at 3:48 amYou did not say if you were trying to do this with a SD or HD (or some other setting of) timeline.
But, work the following and see what happens.
This list contains virtually everything to try to enable:
a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
b. Viewing in the Canvas window on the computer screen.
c. Being able to record on the external FW DV deck or camcorder.
d. Being able to capture from a FW device.If working this list doesn’t cure the problem… you may have a serious PROBLEM!
Try things in this order until you find the “cure”:
1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
2. Make sure you have View (Menu) > External Video> All Frames set.
(If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
10. Make sure you have chosen FW output for A/V:
Final Cut Pro (menu) > Audio/Video Settings… >
Video Playback: Apple FireWire NTSC (720 x480)
Audio Playback: FireWire DV
11. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
12. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
13. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
14. Re-check that your FW cable is well-connected at both ends (or try a new cable).
15. Important: Quit FCP, then Restart FCP.
16. Now again, make sure you have View > External Video > ALL FRAMES set…If it still does not work. “Trash” the FCP Preferences on the Mac
https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html“FCP Rescue” is a free Apple Script that will Trash the Preferences.
It will also restore your user settings afterwards.
Download:
https://www.macupdate.com/info.php/id/14729>Then, start again at my “step 1” above.
Joseph Bradley
November 23, 2005 at 5:16 amThis happened to me once. I looked in my easy settings and it said there was no commection to my deck. It turned out to be a firewire cable that went bad as I was using it.
