Activity Forums Apple Final Cut Pro Legacy FCP HD – cannot play edited sequence on Canvas
  • FCP HD – cannot play edited sequence on Canvas
    Posted by Kinres on April 7, 2005 at 7:34 pm
    I am having a problem with Final Cut Pro HD on my MAC. Basically, in the Canvas window, I cannot watch the sequence I have just edited. When I hit play on the Canvas toolbar, the yellow arrow will move across the bottom of the Canvas screen (indicating the movie is playing); however, the movie will stay frozen on one frame. As soon as I hit stop on the Canvas toolbar, the movie will jump to whatever frame the yellow arrow stopped on. One way I can watch the movie on the Canvas, is if I go to Mark, Play, Every Frame. The Canvas will play, but it will play very very slowly. On top of all of this, sporadically the audio will not play (FCP won
    Rob Forsythe replied 21 years, 4 months ago 3 Members · 4 Replies
  • Bob Delano
    April 7, 2005 at 7:49 pm
    Check to see what size your video is displayed in the canvas… and make it smaller… just hit the 50% option on both viewers and see if it helps
    Bob
  • Rob Forsythe
    April 7, 2005 at 7:53 pm
    Click “Fit to Window” that’s always the correct setting.
    Also, make SURE that the window is not pushed OFF the screen to the top or right edge.
  • Kinres
    April 7, 2005 at 10:09 pm
    I set both the Canvas and the Viewer to “Fit to Window” and still no luck. Thank you for the advice though.
  • Rob Forsythe
    April 7, 2005 at 10:26 pm
    Alright, we’ll bring out the BIG GUNS…
    This list contains about everything to try to enable:
    a. External Monitor VIDEO and AUDIO via FireWire
    b. Viewing in the Canvas window on the computer screen
    c. Being able to record on the external FW DV deck or camcorder..
    Try things in this order until you find the “cure”:
    1. Make sure you have View (Menu) > External > All Frames set.
    (If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
    2. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
    3. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
    4. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
    5. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
    6. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
    7. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
    8. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
    9. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
    10. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
    11. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
    12. Re-check that your FW cable is well-connected at both ends (or try a new cable).
    13. Important: Quit FCP, then Restart FCP.
    14. Now again, make sure you have View > External > ALL FRAMES set…
    If it still does not work. “Trash” the FCP Preferences on the Mac
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    “FCP Rescue” is a free Apple Script that will Trash the Preferences.
    It will also restore your user settings afterwards.
    Download:
    https://www.macupdate.com/info.php/id/14729
    >Then, start again at my “step 1” above.
