Activity Forums Apple Final Cut Pro Legacy FCP HD and AE
  • Posted by Tonya on April 20, 2005 at 1:53 pm
    I am having a small problem. When I render a project in AE to a Quicktime file, and then import it into FCP, it looks alittle blury, not crystal clear. When you view the same file in Quicktime it looks great. So I am guessing that I have a setting wrong in FCP. Any help would be greatly appreciated. Thanks!
    Shannon Brame replied 21 years, 5 months ago 2 Members · 1 Reply
  • Shannon Brame
    April 20, 2005 at 2:44 pm
    For me thats generally just how it works. Do you have a broadcast monitor? It should look fine there. The source/record monitors in FCP aren’t the clearest, expecially with AE type and graphics. But you should be fine. Another thing to check is that you rendered Lower Field First. FCP doesn’t like no frames or upper field first.
