Activity Forums Apple Final Cut Pro Legacy FCP-HD-444-RGB?
  • FCP-HD-444-RGB?
    Posted by Tomas on May 11, 2005 at 7:47 pm
    Supported formats and I/O*
    Uncompressed 8- and 10-bit HD (4:2:2 YUV) via PCI card
    Uncompressed 8- and 10-bit SD (4:2:2 YUV) via FireWire or a PCI card
    This is an extract from apple ‘s website. This means that FCP with a BlackMagic card does not work at 10bits RGB 4:4:4? even if the board captures at 4:4:4 it seams that the software converts the data to work with it. I think that if the software is able to work HD 4:4:4 RGB 10 Bits Apple would remark it right?
    thanks
    tomas
    Walter Biscardi replied 21 years, 4 months ago 2 Members · 3 Replies
  • Walter Biscardi
    May 11, 2005 at 8:12 pm
    When working with 4:4:4 you’ll be capturing either with BlackMagic’s or AJA’s codec so Apple’s’ specs don’t come into play there. FCP is resolution independent so it will support whatever the on-board capture card supports.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Tomas
    May 11, 2005 at 8:29 pm
    Don ‘t you think that if apple can make 444 rgb they would say so?
  • Walter Biscardi
    May 11, 2005 at 8:41 pm
    [tomas] “Don ‘t you think that if apple can make 444 rgb they would say so?”
    No because Apple doesn’t have a 4:4:4 codec, at least not that I’ve seen. not sure if it will be introduced with FCP 5, but both AJA and BlackMagic have 4:4:4 HD workflows available. If Apple alone does not supply the codec, I suppose they won’t mention it.
