Activity › Forums › Apple Final Cut Pro Legacy › FCP Green Screen & how to key it out
Posted by Colleen Fitzgerald on September 13, 2009 at 5:19 amI”m trying to key out a very bright green screen. I found in effects the Blue and Green Screen, I’m just not quite sure how to key out the green perfectly.
Right now I have the Key Mode as – Blue/Green Difference … should this just be on GREEN since its a green screen?
And these are the rest of my settings:
Color Level – 100
Color Tolerance – 80
Edge Thin – 70
Edge Feather 5But I’m still seeing green around this womans head and in the arm pit area. Is this the best I’m going to get it? Or is there something else I could do? A different Key? An additional effect?
Thanks so much!
Richard Harrington replied 17 years ago 5 Members · 8 Replies -
Rafael Amador
September 13, 2009 at 5:42 amHi Colleen,
Don’t use the Blue&Green Screen. Use the Chroma Key filter.
Cheers,
rafael -
John Fishback
September 13, 2009 at 10:33 pmYou may get better results using the Primatte keyer in Motion.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Ron Craig
September 14, 2009 at 3:51 pmI have never used the tools in FCP or Motion for keying. I’ve always used the KeyLight plugin in After Effects. And I think it’s terrific. But it’s also a round-trip out-and-in to FCP. Have the tools in FCS improved to the quality of KeyLight?
Anyone here know?
Rafael Amador
September 14, 2009 at 4:03 pmI don’t think that the default chroma key in FC will works like a 500 bucks third part plugin.
But sure that the one that John suggest will give the best results.
Primatte have been the standard for chroma key for years.
A luxury that used to be reserved for the people able to pay 3-5K for Shake.
Cheers,
rafael -
John Fishback
September 14, 2009 at 4:31 pmKeylight is a great keyer. I usually use it in AE, too. If you’re familiar with it, that’s what I’d suggest. I’ve never has a problem round-tripping to FCP. Just watch that your settings in AE match FCP. I thought you needed to stay in FCP. BTW there is a Keylight for FCP plugin now available, although, it costs a few hundred dollars. https://thefoundry.co.uk/pkg_overview.aspx?ui=76B1D869-EA48-4D89-8F13-FDE18802BCF8
John
Richard Harrington
September 14, 2009 at 4:43 pmThe tools in FCS have not improved a bit.
Check out Popcorn Island for a free script that makes it easy to export your FCP sequences via XML into AE.
You can find out how to use this and key with keylight in this free chapter from my new book Video Made on a Mac
peachpit.com/videomac
Richard M. Harrington, PMP
Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
Rafael Amador
September 15, 2009 at 3:18 amHi Richard,
Had you tried the “Popcorn Island” script?
Its works to send a basic cuts sequence from FC to AE?
Cheers,
rafael -
Richard Harrington
September 15, 2009 at 4:19 amYup..works quite well. See the link for free book chapter and practice media
