FCP Grading
I’m wondering if there is any way to apply a grade to a sequence/ set of clips without having to apply the filter to each individual clip (namely because this is a real pain if you want to tweak the grade later).
I am thinking from an AVID point of view, where the grade can be applied to filler or title segments. In FCP the filter only seems to have effect on the actual segment, and not on any layers beneath it – or am I missing a trick.
So far the only way I can see to do this is to create a nest and grade that. Any alternatives?Many thanks
Franco
