Activity Forums Apple Final Cut Pro Legacy FCP General Error/Not Found
  • FCP General Error/Not Found
    Posted by David Alexander on December 12, 2009 at 12:58 pm
    I am editing a feature-length doc, duplicating sequences when I want to change something but saving the old sequences as references. I was just watching a mixed down version (.mov) of the whole movie and the audio stopped about an hour in and never returned.
    When I referenced my FCP timeline to try to play it, it stops and says Not Found. When I press the spacebar to play it futher, it then says General Error.
    I tried reimporting the footage, didn’t work. I tried making a brand new sequence with the same settings and just copy/pasting the project, still errors in the exact same place.
    HELP!!!
    Rob White replied 15 years, 2 months ago 6 Members · 5 Replies
  • Rafael Amador
    December 12, 2009 at 3:44 pm
    If you haven’t move or deleted any media related with the Reference Movies, this sounds to me to a bit of mess in your system.
    The “General Error” can points in the same direction. In those cases I start by putting my System in order: rebuilding Directories (DiskWarrior) and repairing Permissions.
    If it doesn’t works like that: Trash FC preferences.
    rafael
    http://www.nagavideo.com
  • Jeremy Garchow
    December 12, 2009 at 4:06 pm
    First, I would delete your render files and try again.
  • Jaimz Asmundson
    December 13, 2009 at 9:22 pm
    Also, try opening an autosave file. I’ve found this is the FCP “death error” and basically means your file is corrupted.
  • Luis Sepulveda
    August 26, 2010 at 9:04 pm
    I don’t know how you resolved your problem but this happend to me today. I looked for an autosaved version, rerendered and it worked. Thanks!
    SnowLeopard 10.6.3
    2x3GHzQuad-Core Intel Xeon
    8GB Memory
    Two 24″ Cinema Displays
    Two 1TB/One 500GB GRaid
    FCP 6.0.6
    AJ-SD93
    AJAKonaLH
    Peavey PV6
  • Rob White
    July 14, 2011 at 7:41 am
    I know I’m reviving an old thread, but trashing FCPprefs is a good start, and also try trashing all render files and really any extra files that FCP generates that aren’t crucial to the project. I just had this problem with a very short sequence.
    I Quit FCP, found any file associated with “project_name.fcp” that wasn’t the actual project file, trashed them, and voila. I did copy all of the associated files and made a backup on another drive, just in case something went terribly wrong, but alas, I did not need them. Anyways, re-rendered and it plays back now.
    Another problem I ran into was an error out of memory on a different much longer project, and deleting auto saves, not auto-saving, deleting all render files, and making sure your media/project file/render files are all on the same drive seemed to work for me.
    cheers guys
    -r
