Activity › Forums › Apple Final Cut Pro Legacy › FCP Footage inexplicably has speeded up
Jake Gigliotti replied 16 years, 1 month ago 6 Members · 12 Replies
Dan Flaherty
June 8, 2010 at 10:15 pmGlad I could help John! Also note, if you only change it under the sequence tab on top it will only stay that way for that sequence. you will need to go into your user preferences and change it to 100% there as well. This will keep the setting there for all future sequences.
Jake Gigliotti
July 30, 2010 at 7:07 amI have had the same problem after I exported a project containing XDCAM footage and 7D footage converted to XDCAM. I could not figure a way to slow the footage down considering my sequence settings were all at proper speeds and rendered at a full frame rate. I tried clicking the “enable” on all tracks. A window pops up saying you will lose your render files. Click ok. Then play the clip. Then enable all the video tracks again and try playing them. This saved my project and the upcoming due date. Let me know if this works?
