Activity › Forums › Apple Final Cut Pro Legacy › FCP Firewire connection
Posted by Ceri Allen on August 11, 2008 at 4:37 pmHi
I am using final cut pro 6.0.2 on a G5 mac pro. I am simply trying to playout from a DV-PAL sequence to a mini DV tape using a firewire connected to a sony deck. However final cut is reading the firewire connection as missing.
I have set up the project as DV-PAL, tried refreshing A/V devices, restarting the computer, checking the deck is set to DV record mode, changing the firewire cable, plugging it into a different firewire port, turning the deck on and off.
Now I am all out of ideas.
Any help is appreciated, thanks
Ceri
Blake Porter replied 17 years, 8 months ago 3 Members · 6 Replies -
Jerry Alto
August 11, 2008 at 5:31 pmCeri- Try closing out of FCP and go the Apple menu (apple icon in upper left corner) and select ‘more info’. Does the deck show up there? It may be a firewire conflict with other firewire devices. Don’t proceed to FCP until your computer sees the deck.
HTH,
JerryG5 Dual 3GB Ram
FCP Studio 6.02
External 1 TB SATA Raid 0
Kona LH, Second system w AJA ioLA
Sony Z-1
GV-HD700 -
Blake Porter
January 19, 2009 at 12:16 amSame situation here. For me, no, “more info” does not see the deck. It sees my camcorder, but FCP cannot connect to the camcorder either. Firewire Missing.
Trashed FCP prefs… Old Quicktimes… tried new cable… Tried in iMovie, which recognizes the camcorder but not the deck. Tested computers Firewire port, it works.
Not sure what to do next. Ugh. -
Jerry Alto
January 19, 2009 at 5:54 pmBlake- Let’s start with the deck. Shut down the computer. Disconnect ALL firewire devices except the deck. Power up the deck. Power up the computer. Apple icon in upper left corner>get info>firewire.
Is the deck recognized by the computer? If not there is a problem with the firewire cord from the deck or the deck has a blown firewire port.Now the camcorder. Close out of FCP. Disconnect all other firewire devices. Have the camcorder connected and powered up. Launch FCP. If your settings are right on the camera and FCP your camcorder should be recognized by FCP.
Here is a link for FCP correct settings:
https://www.apple.com/finalcutstudio/resources/supportdevices.php
Hope this helps.
FCP Studio 6.02
Sony Z-1
GV-HD700 -
Blake Porter
January 19, 2009 at 6:19 pmJerry it helped. Final Cut recognized the Z1u. Why now and not several times before, I do not know.
Does not recognize the GV-HD700 deck… “Unknown Device”So… Blown Firewire Port On deck you think?
Thanks for your help Jerry!
Jerry Alto
January 19, 2009 at 7:57 pmBlake- For some reason with HDV the device needs to connected and turned on BEFORE you launch FCP.
Ok, I have the same deck and it’s working fine. You didn’t answer if the computer was seeing the deck.
If you got the “unknown device” dialog box then I presume that was within FCP. The next next thing I’d check are the menu settings in the GV-HD700>Menu>In/Out Rec> HDV OR DV (don’t use auto)> I link conversion> Off.Jerry
G5 Dual 3GB Ram
FCP Studio 6.02
Sony Z-1
GV-HD700 -
Blake Porter
January 19, 2009 at 9:21 pmiMovie would recognize the camera (z1u) but not the deck. I tried this in various start-up situations. iMovie would find the Z1u no matter when I hooked it up, but never the deck.
“About This Mac” would only say “Unknown Device”. The deck settings were correct (I’ll add A/V> Off to your list).
… Called Sony They had me reset the deck, via a pin hole under deck “hold down for 2 seconds”.
They agreed that it sounded like the Firewire port. So, for better or worse, I’ve already mailed it to Texas… 7-10 days. Still under warranty.
Thanks for your effort Jerry really appreciate your time. Now, I hope it was the Firewire Port.
I see your in to fishing? I should pay you to catch me some Halibut. My favorite filet. Brought back 2 boxes from Alaska several years ago. I was in Friday Fish Fry Heaven for a couple months.
BlakeBlake Porter
Field Producer, LLC
(414) 352-9466
blakeporter@mac.com
https://www.fieldproducer.com
