Activity Forums Apple Final Cut Pro Legacy FCP – file error
  • FCP – file error
    Posted by Richard Walton on May 7, 2009 at 8:11 pm
    Recently when I boot FCP it asks for a file from a previous project. The message is:
    “Searching for movie data in file xxxxxxx. Without this file the movie cannot play.”
    The file referenced is a “render” file, again from a previous project.
    I have tried several fixes:
    1) trashing preferences (using “Preference Manager”)
    2) In FCP User Prefs – I unchecked “Open last project on application launch”
    3) repaired preferences on MacBook Pro and ran DiskWarrior on HD.
    Any ideas will be greatly appreciated.
    Shane Ross replied 17 years, 3 months ago 3 Members · 4 Replies
  • Shane Ross
    May 7, 2009 at 8:19 pm
    You have exported a Quicktime reference movie, then reimported it. Now some of the render files that that reference movie references are gone…so you will get that error. To get rid of that error, you need to delete the QT reference movie from the project.
    Shane
  • Richard Walton
    May 8, 2009 at 10:35 am
    Shane:
    Exactly right. Many Thanks!
    Dick
    Dick Walton
    Natural History Services
    https://www.rkwalton.com
    Critters Podcast
    https://www.rkwalton.com/podcast.html
  • Kenny Mikey
    May 18, 2009 at 3:55 pm
    But what if I have hundreds of files and I don’t remember which file I did that to?
  • Shane Ross
    May 18, 2009 at 4:02 pm
    Then you are going to need to check each one…one by one…to see which is the problem file.
    And never do this again. Reference QT movies are good when you are going to Compressor to make a DVD or web movie. Export QT ref…compress for whatever…then delete the file when done. Never use QT reference movies in FCP for editing.
    Shane
