Activity Forums Apple Final Cut Pro Legacy fcp exports stretching
  • fcp exports stretching
    Posted by Christine Metcalf on October 21, 2008 at 6:22 am
    Hi
    When I export my sequence from FCP it renders out all stretched
    my current settings are
    Frame size: PAL 4:3 768×576
    compressor: apple pro res 422
    25fps
    pixel aspect ratio: PAL – CCIR 601 (720×576)
    Anamorphic: ticked on
    The original footage is 16:9
    In my sequence it looks right, as soon as I export it stretches. Am I missing something?
    I have been using compressor at the moment to render out 720×576 and gets the render at the correct aspect ratio, but this doesnt solve the export issue from FCP
    Please let me know if i am doing something wrong? I am very new to FCP
    Christine
    Christine Metcalf replied 17 years, 10 months ago 2 Members · 2 Replies
  • Alex Elkins
    October 21, 2008 at 11:03 am
    Hi Christine,
    It could be that when you play the clip in Quicktime it’s displaying your video with square pixels.
    Try this:
    Open in Quicktime and press Command+J
    Highlight the row that says ‘Video Track’ and then under the Visual Settings menu un-tick ‘Preserve Apsect Ratio’
    Change frame size to 1024 x 576
    That should display a 16×9 video. However, if you need to re-import it to FCP it won’t display correctly unless you change the settings in Quicktime back to 720×576.
  • Christine Metcalf
    October 21, 2008 at 2:13 pm
    Hi there Alex.
    Firstly, thanks so much for your help. I really really appreciate it.
    Your solution is great for presenting a QT movie at the correct aspect ratio.
    But I think I was more after a solution in Final Cut.
    Let me explain:
    We shot some RED footage at 3K resolution 2:1 aspect ratio.
    (Square Pixels to the best of my knowledge) We need to output to PAL at 720 x 576. Obviously this footage was shot with bars for 4:3 so we framed it correctly. We now need to scale down. But clients being clients its not just scaling down as they now want to move the footage around and zoom in at various times. A bit of a pain but….
    The actual question is:
    Should the sequence settings then be:
    Frame Size: 720 x 576 (CCIR 601/ DV PAL 5:4)or should it be PAL 4:3 (which then changes from 720 x 576 of course as the pixels are square)
    and Pixel Aspect Ratio = Square.
    I hope this all makes sense.
    thanks again for your previous help and Hope you can help me out with this new explanation of the problem,
    Regards,
    Christine
