Activity Forums Apple Final Cut Pro Legacy FCP exports funny
  • FCP exports funny
    Posted by Lloyd Paul rivers on January 11, 2012 at 11:32 am
    Im a first year film student so bear with me. I have my finished cut in the timeline, it has been rendered and i exported it using quick time. when i plays i get dropped frames and even a green screen flash frame. i tried just exporting the video and audio separate but it goes out of sync.
    EDIT i have since turned on dropped frames and im getting them. i have turned off all audio tracks so i only have v1 playing and it is still dropping frames even after render?
    n e hints?
    Many Thanks
    Lloyd Rivers
    Tom Matthies replied 14 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Tom Matthies
    January 11, 2012 at 2:21 pm
    First guess would be your drives. Sounds like it (they) might not be fast enough to play back your file. What format is your project?
    E=MC2+/-2db
  • Alex Elkins
    January 11, 2012 at 2:57 pm
    I’m going to take a guess and say that all your media is on a USB drive. If that’s the case then that’s your answer. You need to transfer everything onto a faster drive.
    Slow drives are almost always the reason for dropped frames.
    Alex Elkins
    Twitter: @postbluetv
    http://www.postblue.tv
    View Post Blue showreel
    Shot on RED @ 100fps, Post on FCP/Color: Capoeira Film
    My Vimeo Pro page
  • Rafael Amador
    January 11, 2012 at 3:02 pm
    What computer are you using, what codec is your sequence, what bit depth, what size?
    Are you rendering to the System HD?
    rafael
    http://www.nagavideo.com
  • Lloyd Paul rivers
    January 11, 2012 at 5:33 pm
    Sequence settings are 1920 1080 HDTV 1081(16.9) it was shot on a canon 60d. its actually only 1 video clip that i have ramped up to 700%. All the files/clips/audio are on my mac hard drive which is 2tb
    Many Thanks
    Lloyd Rivers
  • Lloyd Paul rivers
    January 11, 2012 at 8:39 pm
    it seems to be the audio thats causing it. i have exported it as aif and then re imported it but im still getting dropped frames
    Many Thanks
    Lloyd Rivers
  • Lloyd Paul rivers
    January 12, 2012 at 12:03 am
    seems i should have transcoded all the clips to prores before i started. grim
    Many Thanks
    Lloyd Rivers
  • Tom Matthies
    January 12, 2012 at 4:43 pm
    Don’t edit from your system drive. Use a second internal drive (at least) or an external RAID if possible for best results. Depending on the format of your HD clips, you will need some fairly fast drives.
    E=MC2+/-2db
