Activity Forums Apple Final Cut Pro Legacy FCP export to Quicktime
  • FCP export to Quicktime
    Posted by Lau Leck gee on March 16, 2007 at 3:02 am
    GDay.
    As a test for a multi-screen display, i want to have a couple of HD-sized footages arranged in a box formation (4×4) within a single sequence in FCP. Hence, I am expected to set the sequence size to maybe around 7680×4320. However, FCP forces the maximum size to 4000×2000. Why is this so? Also, when i tried to export a Quicktime from this 4000×2000 sequence, all it gives me is black and without audio but with the correct duration. Has anyone encountered this before?
    Lau Leck gee replied 19 years, 5 months ago 3 Members · 3 Replies
  • Jason Lyons
    March 16, 2007 at 5:54 am
    Interesting. Can you explain the “Multi-screen display” a bit further? Are you doing projectors? What output I/O are you using ?
    You are most likely going to have to size down the footage to fit into the highest sequence size your I/O will support.
    hope this helps
    jason
  • Rafael Amador
    March 16, 2007 at 8:48 am
    I dont know if the limit in resolution is a matter of QT or FC. But If you want to work with those sizes iI think you need a program that support un-limited resolution for example Shake. I guess AE7 can manage such a files too.
    Cheers,
    rafael
  • Lau Leck gee
    March 18, 2007 at 2:34 pm
    Tks Rafael, I have yet to test putting all the footages together in After Effects. I will let you know if that is successful. I may encounter problems again when I render out from AE to Quicktime but lets hope it works. Cheers!
