Activity Forums Apple Final Cut Pro Legacy FCP export to MXF
  • FCP export to MXF
    Posted by Frans Suijs on January 23, 2009 at 11:20 am
    Hi all,
    Our broadcaststations from now on want commercials to be delivered in MXF format instead of tape. Is there a way to export MXF files directly from FCP? Or is episode pro the only option?
    Thanx!
    Frans
    Rick Hunink replied 11 years, 11 months ago 19 Members · 32 Replies
  • 32 Replies
  • Andy Mees
    January 23, 2009 at 2:09 pm
    Frans
    It depends on the codec needed for delivery … MXF is just the container.
    Sony’s free XDCAM Transfer includes an FCP Export component that will rewrap your DV, IMX, HDV or XDCAM HD variant edits to MXF
    Or maybe this is what you need: https://mxf4mac.com/mxf4qtexport
    Best,
    Andy
  • Frans Suijs
    January 23, 2009 at 2:48 pm
    Thanx,
    I guess I don’t need a wrapper, it needs to be a real MXF file. Thanks for the link. I also heard a MXF export option for FCP is being developped.
    Regards,
    Frans
  • Andreas Kiel
    January 23, 2009 at 3:43 pm
    Frans,
    MXF is a wrapper!
    There can be many things in there. So first check with your customer what kind of MXF he wants/can work with.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
  • Jeremy Garchow
    January 23, 2009 at 3:56 pm
    [Andreas Kiel] “So first check with your customer what kind of MXF he wants/can work with.
    Exactly. It’s like a client saying they want a Quicktime movie…
    Okay, is that Uncompressed or MPEG1? HD or SD? We don’t know until the client tells us the details.
    The link to MXF4mac (MXF4QT Export) will export the following types of MXF:
    MXF OP1a GC (D-10) 625/50 PAL, 525/60 NTSC
    IMX 30, 40 and 50 Mb/s
    OP1a refers to audio and video multiplexed to a single file, unlike Panasnoic P2 MXFs which are OP-atom which means demuxed (separate) audio and video.
    This is a guess, but I would imagine that your broadcaster wants one of the SMPTE approved MXF formats.
    Jeremy
  • Andreas Kiel
    January 23, 2009 at 4:14 pm
    Jeremy,
    Could you send me your email address. There is (maybe) some cool stuff you can test with the mxf4mac P2 workflow.
    Andreas
    kiel at spherico dot com
    Spherico
  • Jeremy Garchow
    January 23, 2009 at 4:25 pm
    Surely.
    editstation at gmail dot com.
    Jeremy
  • David Keslick
    January 23, 2009 at 9:23 pm
    You may also want to check out DVFilm Raylight for Mac. With Raylight you can go back to .mxf for delivery.
    Hope this is helpful.
    Dave Keslick
    DVFilm.com
  • Bouke Vahl
    January 24, 2009 at 12:31 pm
    Frans,
    I suspect you’re Dutch…
    What you need is simple. Export to 4 channel MXF using XDcam Transfer.
    (you don’t need a XDcam player to do so, it can output to harddisk)
    Ster accepts that, so probably all the others do too. (Same specs from SPOT).
    I’ve only tested with STER though.
    DO NOT USE EPISODE PRO.
    Although the latest two versions can make compatible files, the quality is HORRIBLE.
    Next step is to create correct XML and rename your output file.
    Use this little util for that, quite impossible to make mistakes then.
    https://www.videotoolshed.com/?page=products&pID=37
    Bouke
    smart tools for video pro’s
  • Anders Haavie
    January 25, 2009 at 6:33 pm
    You can export directly from fcp… believe it or not.. Search for mxf at this forum
    Anders
    Xraid-Xserve-Xsan-Xeverything
  • Frans Suijs
    January 30, 2009 at 10:01 am
    Hi all, thanks for the comments!
    I’ll try your solution Bouke. I’m from the Netherlands as you already guessed. You have some nice tools on your website!
    Anders, if I look for mxf I find millions of posts. Can you describe how to export directly from FCP? Do you use the sony mxf plugin?
    Regards,
    Frans
Page 1 of 4
