Activity Forums Apple Final Cut Pro Legacy FCP export of MXF for Pro Tools
  • FCP export of MXF for Pro Tools
    Posted by Tino Zidore on October 15, 2009 at 11:33 am
    Hello!
    I’m trying to export a sequence from Final Cut 7 to Pro Tools, as an MXF.
    – I use Export – Sony XDCAM in the “File” menu, and it works fine, I get the MXF file I want.
    Trouble starts when I try to open it in Pro Tools, a pop-up with the following message appears:
    “The selected video clip’s compression level is incompatible.”
    Does anyone know a workaround for this problem?
    Kind regards’
    Tzidore
    Jeremy Garchow replied 16 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    October 15, 2009 at 12:46 pm
    Hi Tino,
    I have no much experience with MFX files, but I have been having a look to the MFX options of exporting from FC via Export to XDCAM.
    I guess that Protools can not cope with the codec, size or data rate of your clip.
    I find out that MFX supports DV.
    Just drop your movie in a DV sequence and Export to XDCAM MFX.
    You need to have 4 channels audio.
    Best,
    rafael
    http://www.nagavideo.com
  • Tino Zidore
    October 15, 2009 at 12:54 pm
    Hi Rafael
    I have already tried that and I’m sorry to say it doesn’t work.
    Have you got it to work in Pro Tools with these export settings you mention?
    /tzidore
  • Rafael Amador
    October 15, 2009 at 1:22 pm
    [Tino Zidore] “Have you got it to work in Pro Tools with these export settings you mention?
    No.
    My only experience with MFX is to give EX-1 QT files to my PC mates.
    No idea if this may be a problem with the MFX files or a problem with Protools.
    Check if the MFX you have exported can be open with a video application (PP, AVID,..) or with VideoLan.
    rafael
  • Jeremy Garchow
    October 15, 2009 at 6:21 pm
    Why MXF? Don’t you mean OMF?
  • Rafael Amador
    October 16, 2009 at 11:41 am
  • Tino Zidore
    October 16, 2009 at 11:46 am
    It is a MXF I need. It’s for the sound department, and I have already made a AAF for them, but they are asking for a MXF aswell.
  • Jeremy Garchow
    October 19, 2009 at 7:09 pm
    [Tino Zidore] “It is a MXF I need. It’s for the sound department, and I have already made a AAF for them, but they are asking for a MXF aswell.”
    You need to find out exactly what they need as MXF is just a container. It’s like saying, “Give me a Quicktime Movie”. It could mean anything. I highly doubt they want an XDCam MXF file.
    Jeremy
