Activity › Forums › Apple Final Cut Pro Legacy › FCP export issue with transparent layer
  • FCP export issue with transparent layer
    Posted by Boris Undorf on November 30, 2009 at 8:50 pm
    I am exporting a project from FCP Studio 2 in which several elements were imported .gif files of images on a transparent alpha layer. I keyed out the background using “Luma Key”. I also put another filter “Earthquake” onto these clips. Now, when I export the project using Compressor, in any format other than current settings, the background of these images shows up as a transparent green box. This happens with m2v files, DV/NTSC files, etc.
    What do I do?
    Boris Undorf replied 16 years, 10 months ago 3 Members · 5 Replies
  • Shane Ross
    November 30, 2009 at 8:58 pm
    The only codecs that support Alpha Channels are ANIMATION and ProRes 4444. ANything else and you lose transparency.
    Shane
  • Boris Undorf
    November 30, 2009 at 9:01 pm
    Thank you so much Shane for clearing that up so quickly.
    So if a client requested a H264 file, I am screwed, right?
  • Shane Ross
    November 30, 2009 at 9:20 pm
    [Boris Undorf] “So if a client requested a H264 file, I am screwed, right?”
    If they want one with an Alpha Channel, then yes. That is an impossible request to fulfill.
    Shane
  • Zak Mussig
    November 30, 2009 at 9:30 pm
    This came up a lot a couple of years back and became a big part of my workflow for a very big project (to me at least) that I was working on.
    Compressor is no good, and since you’re in FCS2 ProRes 4444 is out. The way to export from FCP with alpha is:
    1) Move your video up to v2 or above
    2) don’t render – that bakes in the black pixels FCP uses to display transparency
    3) Export > QuickTime Movie, self-contained, Animation codec
    That should give you a .mov file with an alpha channel that holds up in any QT based app. The file will be big.
    Zak
  • Boris Undorf
    November 30, 2009 at 9:34 pm
    Excellent advice, thank you Zak. I will give that a shot.
