Activity › Forums › Apple Final Cut Pro Legacy › FCP Export
FCP Export
Posted by Goutom Ain on February 25, 2013 at 8:02 amIs there any way to export a video from fcp with TCIN=0 without moving the clip to the start of timeline. I need all video to get TCIN=0 to play the files in our automation.
Nick Meyers replied 13 years, 6 months ago 3 Members · 4 Replies -
Shane Ross
February 25, 2013 at 10:50 amWhat is “TCIN=0?”
Timecode IN to start at 00:00:00:00?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Goutom Ain
February 25, 2013 at 1:28 pmYes Timecode IN=0 i.e. every file need to get this timecode while exporting from FCP.
Shane Ross
February 25, 2013 at 2:24 pmThe only way to get that is to have a sequence with the timecode you want.
Shane
Little Frog Post
Nick Meyers
February 26, 2013 at 7:18 pmif you export the clips using quicktime conversion, the TC track will start at zero,
but you’d be transcoding, or re-compressingquicker (by a matter of minutes, possibly seconds) than setting a bunch of sequences to TC0 would be to batch export your clips,
then bringing them back into FCP and changing the TC to zero.nick
