Activity Forums Apple Final Cut Pro Legacy fcp error at launch
  • fcp error at launch
    Posted by Kari on October 26, 2006 at 4:37 pm
    Hi there. I am working on FCP 5.1.1
    OS 10.4.7, dual 2.5GHZ Power PC G5 with 8GB RAM.
    With BlackMagic Card (not my system–will investigate which type of card)
    When I launch my system the following dialog box pops up:
    “One or more unsupported enabler files are installed.
    Blue render bars will appear in the Timeline to
    indicate areas of real-time playback that may drop
    frames as a result of this non-standard
    configuration.”
    My sequence and media are Black Magic 4:2:2 10bit uncompressed.
    Everything plays back ok. I can render and create masks and do blur effects.
    I am given blue render bars when I apply a simple dissolve and when I try to do color correction.
    Any ideas what this error means?
    Where are the unsupported enabler files?
    This isn’t my machine so I do not have all the info about the config just yet.
    Thanks for any clues or info you can throw my way.
    Best
    Kari
    Scottyp replied 18 years, 10 months ago 2 Members · 1 Reply
  • Scottyp
    November 5, 2007 at 6:56 pm
    ever figure that out? I still have that error as well.
    scott
