Activity Forums Apple Final Cut Pro Legacy FCP Equivalent to AVID ‘Select Unreferenced Clips’
  • FCP Equivalent to AVID ‘Select Unreferenced Clips’
    Posted by Jim Blokland on May 4, 2006 at 1:09 am
    Hello all:
    Got a project with lots of versions and want to clear out old unused media. Can anyone familiar with AVID’s ‘Select Unreferenced Clips’ walk me through a similar procedure in FCP 5.0.4? Thanks in advance.
    JIM.
    OSX.4.3
    Dual 2.7 G5
    3.5 GB RAM
    Radeon X800 XT
    Kona 2 / K-Box
    Seritek 1.2 TB RAID
    AVID XPRESS PRO/MOJO
    Annaël Beauchemin replied 20 years, 4 months ago 3 Members · 2 Replies
  • Zander
    May 4, 2006 at 2:21 am
    ok, i did this the other day, you go to edit, find, and than one of the options is find all un used clips, u can grab tehm all, and there will be a button that says delete all
    now i don’t have fcp open but thats what i believe is the course of action
    check your helpfiles for more details
    Aaron Zander-Student editor
    If it’s out there and it does somethign to something,
    teach me how to use it
    Powerbook g4 1.5 GHz (it might not be big, but i can take it on set
    fcp 5, ae 6.5pro adobe cs2
  • Annaël Beauchemin
    May 4, 2006 at 4:32 pm
    what I do is to delete clips one by one. When a clip is used in a sequence, FCP will pop up a dialog saying the the clip is a Masterclip and blah blah. Hit cancel. If it’s not used in any sequence, it will be deleted without any warning.
    Of course, if you have thousands of clips, this will be a pain…
