Activity Forums Apple Final Cut Pro Legacy FCP DVD Chapter Markers
  • FCP DVD Chapter Markers
    Posted by Michael Garske on February 6, 2008 at 6:39 pm
    Hi, I’m trying to burn a SD project that I have to DVD. I believe there is some way to insert DVD chapter markers into a longer project so that it can be recognized by a burning when I export.
    How can I insert these markers? What program should I use to burn my disc & are there any steps I should know about to make this work properly?
    Once again, Thanks a lot for the help.
    Thom Obarski replied 18 years, 6 months ago 3 Members · 2 Replies
  • Thaxter Clavemarlton
    February 6, 2008 at 7:33 pm
    Duplicate your Sequence in FCP and use the Dupe for the DVD if you want to leave your original “unaltered.”
    1. Delete all markers: Mark > Markers > Delete All.
    2. Park the cursor in the Timeline EXACTLY where you want the first chapter marker.
    3. Make sure to “DE-select ALL” (Shift-Apple-A) so no timeline files are highlighted.
    4. Hit the “m” key TWICE. It will leave a marker on the timeline.
    5. Click “Add Chapter Marker”
    6. In TOP Box: Type a Chapter Name (and Number (1. 2. 3.) if wanted).
    7. Click OK
    Move Cursor to where you want the next Chapter to begin and Repeat steps 4 thru 8.
    Continue until all Chapters are marked. (Don’t forget to hit “Save”, just in case.)
    A. Choose File > Export > QT Movie.
    B. In the pop-up menu, choose Markers > “Chapter Markers” then Save.
    C. After the export, drop that exported QT movie file into a newly-opened blank iDVD window.
    D. Make any menu style and name changes in iDVD and burn, baby, burn.
  • Thom Obarski
    February 6, 2008 at 10:23 pm
    WELL PUT, THAT SAME PROCESS WORKS FOR BURNING IN DVD STUDIO PRO IF YOU WANT TO GET MORE COMPLICATED!
    SORRY FOR ALL CAPS AM RENDERING IN AE RIGHT NOW!
    ~T
    “This is post, you can’t fix it after this.”
