Activity › Forums › Apple Final Cut Pro Legacy › FCP dropping Frames
  • FCP dropping Frames
    Posted by Ben The camera guy on June 10, 2006 at 8:45 pm
    I have a quad core powermac with 4.5 gb of memory…i’m tring to capture some footage and, after a few seconds, it says the capture stops because of dropped frames. is there any way I can tell fcp to ignore dropped frames and continue capturing? thanks…also, on an unrelated note, i have a blackmagic decklink pro hd pci-e card and when I capture the video is not being previewed on my external monitor (even with it set to monitor on the external)…thanks…
    Frank Nolan replied 20 years, 3 months ago 4 Members · 3 Replies
  • Walter Biscardi
    June 10, 2006 at 9:14 pm
    What are you capturing to? You should be capturing to an external array. There’s no info in your Profile, so I’ll assume you’re trying to capture to your main internal drive and that’s a no-no.
    In the User Prefs you can tell FCP to ignore Dropped Frames. But if you are really capturing dropped frames, they will be in your video.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Kevin Monahan
    June 11, 2006 at 7:30 pm
    Don’t put your head in the sand and ignore the dropped frames warning. Try and discover the real root of your problem. Dropped frames are usually caused by drives that are too slow, clips that are too long or both.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Frank Nolan
    June 12, 2006 at 12:22 am
    [walter biscardi] “But if you are really capturing dropped frames, they will be in your video.”
    Well technically they wont be in your video, ’cause they’ve been dropped:-)
