Activity Forums Apple Final Cut Pro Legacy FCP dropping frames on playback over RAID
  • FCP dropping frames on playback over RAID
    Posted by Pkdumas on October 20, 2006 at 7:51 pm
    I am getting dropped frames very often while playing back the timeline. I am editing 720p24 DVCPRO HD and HDV together in this timeline. The media is on an Xserve RAID, which I understand is supposed to eliminate these kinds of problems for HD. I’ve have premium support contract for the RAID and spent 2 hours on the phone with them, making sure all my settings are right. They said I should probably talk to “Pro Application Support” folks for FCP, but I’m hoping to avoid buying that support. Any ideas where I should start? I think it’s somewhere beyond the obvious like RT settings or anything else the app suggests. The G5 has plenty of power.
    -Paul
    John Calhoun replied 19 years, 10 months ago 7 Members · 10 Replies
  • 10 Replies
  • Bouncing Account needs new email address
    October 20, 2006 at 7:57 pm
    Did you try to MIXDOWN the audio?
  • Pkdumas
    October 20, 2006 at 8:05 pm
    Mixing down the audio every time I want to watch my timeline doesn’t seem to be very efficient. Am I not understanding you?
    -Paul
  • John Christie
    October 20, 2006 at 8:30 pm
    Paul
    If you come from an Avid background, then mixdown sounds like the wrong thing to do, because it replaces all your audio tracks with a mixed down stereo pair. But in FCP all it does is create a temp audio file for playback. Try it, it usually gets rid of 90 percent of dropped frame issues, especially if you know your storage speed isn’t an issue.
    Cheers
    John Christie
    Keyframes Editing
  • Pkdumas
    October 20, 2006 at 9:25 pm
    I’m familiar with mixing down in FCP. I did try and it helped, but still got some dropped frames. I can’t say that it is not a RAID problem, but the high-end tech support basically said if everything is okay in RAID Admin, then it’s not that.
    -Paul
  • Ernie Santella
    October 20, 2006 at 9:35 pm
    Is your RAID full or nearly full? When they are nearly full, the transfer slows down.
    Ernie Santella
    Santella Film/Video Productions
    http://www.santellaproductions.com
  • Pkdumas
    October 20, 2006 at 10:39 pm
    The RAID is not even close to full.
    -Paul
  • Jeremy Garchow
    October 20, 2006 at 11:29 pm
    [pkdumas] “I am getting dropped frames very often while playing back the timeline. I am editing 720p24 DVCPRO HD and HDV together in this timeline. “
    This is your problem. You need to capture everything to the same codec. FCP does not handle mixed codecs/resolutions in the same timeline well at all. i would suggest capturing/transcoding your HDV material to 720p24 DVCPRO HD.
    Jeremy
  • George Strother
    October 21, 2006 at 1:58 am
    Do you have “Report dropped frames on playback” selected in User Prefs/General?
    If yes, are you getting dropped frame warnings or just seeing skips or stutters?
    George
    Light Images
  • Pkdumas
    October 23, 2006 at 2:44 pm
    When I uncheck or deselect the “Report Dropped Frames” warning it has moments where it plays back very clunky, but obviously no warning. Obviously, when I have the warning option selected, it gives me a warning message about dropped frames. Whether it’s noticeable or not, I can’t have dropped frames.
    -Paul
  • John Calhoun
    October 25, 2006 at 6:48 pm
    Are you sure that all of the footage is on the raid? Often, when I’ve had to trash preferences, the scratch disks will get reverted to the internal computer hard drive. I’ve accidently digitized to the computer drive.
    pxlmvr
