Activity Forums Apple Final Cut Pro Legacy FCP dropping frames on capture when using DVI switcher
  • FCP dropping frames on capture when using DVI switcher
    Posted by Michaelle Stikich on April 23, 2009 at 9:10 pm
    Hi all,
    I feel like I’ve been able to do this in the past. I have two MacPros attached to a Gefen DVI switcher (only one monitor is setup to switch between the machines). As I begin a capture on Machine 2, I switch to Machine 1 and the capture on Machine 2 drops frames and stops the capture.
    My specs:
    -capturing to an Xsan 4.5TB, with prores 4:2:2, 720×486, 29.97fps
    -FCP version 6.05, QT 7.6, OS 10.5.6
    -Machine 2 has a dedicated mouse and keyboard attached, plus the mouse/keyboard attached via the switcher (note, Machine 2 does NOT have its own display)
    any ideas?
    Michaelle
    Michael Gissing replied 17 years, 4 months ago 3 Members · 3 Replies
  • Michaelle Stikich
    April 23, 2009 at 10:19 pm
    nope, I let it run for almost 20 minutes without a dropped frame before I had to stop the capture, so I know that there is not a problem with the scratch disks or the computer itself, at least in this case.
  • Zane Barker
    April 23, 2009 at 10:29 pm
    Does it do the same thing if you do not switch?
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Michael Gissing
    April 23, 2009 at 10:38 pm
    I use the same DVI switcher, but would never consider switching during capture. I haven’t had capture issues with it so it is clearly a problem switching during a critical operation like capture.
