Activity Forums Apple Final Cut Pro Legacy FCP, dropped frames on playback
  • FCP, dropped frames on playback
    Posted by Rew on July 4, 2005 at 6:24 pm
    Hello,
    I’m having trouble with dropped frames during playback. I’m running FCP 4.0.1 on a dual 1.8 G5 w/ 1.25G of ram. I capture the media via firewire to a maxtor 300gig SATA internal hard drive. I’m getting dropped frames regularly when playing back from the timeline, even if I close all other projects & timelines, export the show to a FCP movie, import that movie & play from there. The shows aren’t particularly long or complex…. Maybe someone has some suggestions? Thanks!
    Thaxter Clavemarlton replied 21 years, 2 months ago 3 Members · 2 Replies
  • Steve Eisen
    July 4, 2005 at 6:44 pm
    Look down a few posts!
    G5 Dual 2.5 160GB System 400GB Media Drive ATI 9800 256MB 6 GB RAM
    Dual Gig Quicksilver 1GB RAM 80 GB System drive (3) 250 GB internal media storage
    15″ Al Powerbook 1.25 1GB RAM
    OS 10.3.8 FCP 4.5, DVDSP 2, QT 6.5, Boris Red 3GL 2.45 TB External Stor
  • Thaxter Clavemarlton
    July 4, 2005 at 9:09 pm
    Questions like this are posted very frequently. And many (most?) of the problems are solved by a simple procedure.
    There is a function in FCP that is often overlooked… and it can help with many audio and video “skipping”, “sticking” and “missing” problems.
    You should “Mixdown” the Audio for playback before you dub out of FCP, or during the edit, if you have audio/video stuttering, drop-outs or freezes.
    NOTE: Mixdown has even been demonstrated to help with slipping, skipping problems (or “missing” audio clips) for files being EXPORTED as QT (or similar) files out of FCP.
    First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
    Sequence Menu > Render Only > Mixdown.
    You should see a dialog box telling you its rendering.
    It might seem to make little sense that “Mixing down” even simple audio tracks will “fix” complex video “freezes” or random audio dropouts to tape or export, but it CAN.
    NOTE: It does not matter of you only have one audio track, if there are random freezes during output, you should try the Mixdown.
