Activity Forums Apple Final Cut Pro Legacy FCP doesn’t recognize my deck !!
  • FCP doesn’t recognize my deck !!
    Posted by Nicole Cattell on May 22, 2007 at 6:04 pm
    Hello – I just upgraded my G5 to 10.3.9 and installed QT pro 7. Ever since then, FCP does not recognize my external deck which is connected via firewire. How do i get it to recognize my deck? I would be so grateful for any help as i have to edit something tomorrow morning on the system!! Also – running FCP HD 4.5. Thank you!
    Nikagain
    Nicole Cattell replied 19 years, 3 months ago 3 Members · 4 Replies
  • Steve Braker
    May 22, 2007 at 6:21 pm
    If I remember right FCP 4.5 isn’t compatible with OS 10.3.9. You need to downgrade the OS or upgrade FCP. Lots of info on this in the Apple forums.
  • Steve Braker
    May 22, 2007 at 7:33 pm
    That wasn’t entirely correct – there is another solution but I don’t know what it is. Search here or especially in Apple forums on “10.3.9” and “4.5” – there’s a specific tweak outlined. Good luck.
  • Eric Peterson
    May 22, 2007 at 9:42 pm
    Check this out and see if it will help.
    https://docs.info.apple.com/article.html?artnum=301852
  • Nicole Cattell
    May 22, 2007 at 11:45 pm
    THANK YOU SO MUCH!!! THAT WORKED!!!
    Nikagain
