Activity Forums Blackmagic Design FCP doesn’t output 1:2 res image.
  • FCP doesn’t output 1:2 res image.
    Posted by Juliett on February 9, 2006 at 1:46 pm
    Hi
    I have an edit suite running on FCP v 5.0.2 running on Mac OS X with a Decklink Hd Pro.
    The problem is that the image only outputs as 1:1 resolution.
    In the in HD Link settings, I tried to switch it back to 1:2
    double size zoom, but it still displays the image as 1:1 res.
    Before you suggest it; I did re-start and shut down the computer many times with no result.
    When I feed the image directly from the Digi deck (SDI out) I still get only 1:1 res picture. I tried a different hd link box and again this didn’t make any difference.
    Could it be that there is a fault with the Apple Cinema Display?
    Does anybody have any suggestions.
    Juliett replied 20 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
