Activity Forums Apple Final Cut Pro Legacy FCP doesn’t like exports to ProRes4444 25p
  • FCP doesn’t like exports to ProRes4444 25p
    Posted by Nick Meyers on September 18, 2013 at 10:48 pm
    capturing from tape, my initial capture was PR4444.
    that proved too hard for the CPU, resulting in many dropped frames,
    so i’ve recaptured as 10-bitRGB.
    I have to bust it up into smaller parts, so i figured i;d transcode to 4444 as i do that.
    but the files i create doing that behave strangely:
    when i put them into a sequence and say YES, i want the sequence to match the clips,
    i still get a green render bar.
    i can’t see ANY properties that don’t match,
    the clips have NO attributes on them (motion effects, filters, etc)
    another clue:
    when i change my sequence from “render in 10bit YUV” to “render in 8bit YUV”, or “render in RGB”
    the render line changes from green to the blue/grey of “full”
    now, the original 4444 captures sit in a timeline just fine,
    but even if i i export from these clips, there are issues:
    Batch Exported files get the green line in a timeline,
    a MANUAL export reveals something odd: i don’t get the “item settings” option in the export window,
    i get the Apple Intermediate option as the default,
    I’ve seen that when the clip you want to export is non-standard.
    so why can’t i export ProRes4444 25p from FCP??
    nick
    Samuel Enblom replied 12 years, 11 months ago 2 Members · 2 Replies
  • Nick Meyers
    September 19, 2013 at 12:25 am
    it was the alpha channel!
    nick
  • Samuel Enblom
    September 19, 2013 at 6:22 am
    Im glad you figured it out, best of luck with your project!
