Activity Forums Apple Final Cut Pro Legacy FCP does not save the capture fully
  • FCP does not save the capture fully
    Posted by Rasikacarya Das on September 15, 2011 at 12:35 pm
    It appears that fcp is capturing properly but at the end of the tape when verified the size of the capture, it shows much less than expected. For example it would be around 4 to 6 GB instead of around 13 GB per DV.
    Machine/Software Specifications: Mac OS X 10.6.8 with 2GZ Intel CORE DUO, FCP 7
    Can anyone help me out !
    Rasikacarya Das replied 15 years ago 2 Members · 2 Replies
  • Jerry Hofmann
    September 18, 2011 at 5:19 pm
    What format are you capturing? DV?
    Jerry
  • Rasikacarya Das
    September 19, 2011 at 9:05 am
    We are using HDV 1080i50 format. But we have seen the same problem with DV also.
    But, now we have discovered the problem and the solution.
    Recently we have added a new Hard disk which was formatted in FAT32(windows format) and because it allows only 4 GB file size we were having problems. Now we have re-formatted this hard drive using the format Mac OS Extended (Journaled) and the problem is resolved.
    Anyways, thank you Jerry for your response.
