Activity › Forums › Apple Final Cut Pro › FCP Delete
  • FCP Delete
    Posted by Guy Crossman on September 3, 2018 at 3:19 pm
    I know this is simple beyond words, but I’ve just moved from Avid and know I’m doing something stupid. When I mark up a range and hit delete, it lifts the marked section- how do I get it to delete the section but get the 2 sides to join up? Thanks
    Steve Connor replied 8 years ago 2 Members · 3 Replies
  • Steve Connor
    September 3, 2018 at 6:31 pm
    Are you using range select to select a section that is above the primary? If so it won’t ripple delete unless that clip is in a secondary storyline. It will only ripple delete if you mark in and out on the primary storyline.
    It’s one of the tricky things when you transition from another NLE
  • Guy Crossman
    September 4, 2018 at 5:51 am
    Right! Many thanks Steve, as you say a bit of a learning curve from Avid! Thanks again Guy
  • Steve Connor
    September 4, 2018 at 8:57 am
    Stick with it, there is a point where it all makes sense 🙂
