Activity › Forums › Apple Final Cut Pro Legacy › FCP damaged file
FCP damaged file
Posted by Javad Ahmadi on March 16, 2011 at 7:51 pmHi Guys;
I have FCP 7.0.3 file which got corrupted. Now when I try to open my Final application crushes. Is there any way I can recover. Please advise.Thanks
Javad Ahmadi
Alive ProStudiosJavad Ahmadi replied 15 years, 6 months ago 3 Members · 6 Replies -
Frank Nolan
March 16, 2011 at 8:08 pm[Javad Ahmadi] “I have FCP 7.0.3 file which got corrupted. Now when I try to open my Final application crushes. Is there any way I can recover.”
You need to be little more specific. Is the file you are talking about a session file or is your application corrupted?
Can you open the FCP application from the FCP icon in your applications folder? -
Javad Ahmadi
March 16, 2011 at 8:14 pmThanks Frank.
The application works just fine. There is no problem with other FCP files I have. When I try to open this particular file, the application crushes.
regardsJavad Ahmadi
Alive ProStudios -
Frank Nolan
March 16, 2011 at 8:22 pmTry launching the FCP from the icon in the apps folder then going file>open>your project, and see if it open from within FCP.
If that doesn’t work try going to the autosave vault and see if you can open the latest version in there. -
Javad Ahmadi
March 16, 2011 at 8:28 pmI already tried that. I tried it on a separate computer, same application crush happens. I sent it to a friend. The file crushed his application.
Do you recommend FCS Maintenance Pack? Do you think that might fix my problem.
I appreciate your advise and assistance.
thanksJavad Ahmadi
Alive ProStudios -
Shane Ross
March 16, 2011 at 8:34 pmI HIGHLY recommend the Maintenance Pack. There is a PROJECT REPAIR app in there that does wonders.
Shane
Read my blog, Little Frog in High Def -
Javad Ahmadi
March 16, 2011 at 8:40 pmThanks Shane and Frank.
I just purchased it.
I will let you know how it goes.
kindest regardsJavad Ahmadi
Alive ProStudios
