Activity Forums Apple Final Cut Pro Legacy FCP Crossfade Question…
  • FCP Crossfade Question…
    Posted by Jon Downs on May 6, 2005 at 1:57 pm
    hello. this may be a silly question…but i’m wondering if there is a setting to make a one second crossfade dissolve work with two shots that do not have any overlapping footage…for example, snipping a clip, and insterting a crossfade (the two segments would automatically move to allow the one second crossfade). thanks.
    Kevin Monahan replied 21 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
  • If you do not have enough media at the end of your clip for a dissolve:
    I suggest that you make a STILL-FRAME on the last frame of your clip and fade THAT out for as long as you want.
    -OR-
    Change the SPEED of your clip (slow-mo) and that will allow for a longer fade-out length.
    -OR-
    Go back to your original tape and CAPTURE a longer clip (make the OUT-point LATER)
    and then edit this longer clip in instead of the one you’re using now.
  • Jon Downs
    May 6, 2005 at 2:18 pm
    well, here is my issue. i’d like to capture an entire tape, split it out with DV Start/Stop, and add a crossfade between every shot. so i need some way of doing it fast, because the tapes are over an hour long each.
  • Chris Poisson
    May 6, 2005 at 2:26 pm
    ghetto,
    You can put the second clip on v2 and overlap it for the length of dissolve you want, and use the opacity band on the top clip.
  • Jon Downs
    May 6, 2005 at 2:34 pm
    well the issue is, there will be about 200 clips…and i need to do it every other day.
  • Then you might want to do this in iMovie.
    I just read that the latest version will automatically place a dissolve at every start/stop point on the imported tape if you choose this option.
  • Jon Downs
    May 6, 2005 at 2:42 pm
    you know, that’s a pretty good idea. thanks!
  • Kevin Monahan
    May 6, 2005 at 5:42 pm
    But dude, that’s not editing! Yer supposed to take out all the bad shots. You know…the ones that accentuate the hairs on granny’s chin?? 😉
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
